2005 Cadillac SRX Logo
Anonymous Posted on May 28, 2016
I just purchased a 2005 cadilllac srx v8 n i cannot get the third row seat tto function? Help?
Jeff Armer
Level 3:
  • Cadillac Master 15,575 Answers
  • Posted on May 29, 2016
Jeff Armer
Cadillac Master
Level 3:
Answers
15575
Questions
Helped
7104156
Points
73899
Rear Seat Switches
There are three push button switches that are used to operate the power folding seat; front stow switch, rear stow switch, and recline switch. The front stow switch is located in the right rear quarter trim panel just behind the second row seat. The rear stow and recline switches are located in the right rear trim panel just inside the liftgate. Battery positive voltage is supplied at all times to all three switches from the FFS SW Fuse located in the left rear fuse block. The folding seat will operate only in a supervised mode, i.e. press and hold the selected switch button through the entire cycle of operation, or release the switch when the desired seat position is reached. When any folding seat switch is pressed, it sends a 12 volt signal through the switch signal circuit to the RSM. The RSM then commands the appropriate seat motors to move in response to the switch signal.
Rear Seat Module and Power and Ground
The rear seat module controls the position of the third row seat. When commanded it moves the seat from the seated position to the stowed position, or, from the stowed position to the seated position. With the seat in the seated position, the RSM can also move the angle of the seat back forward or rearward.
Battery positive voltage is supplied at all times to the module through the battery positive voltage circuit and the FFSM fuse located in the left rear fuse block. This voltage is used to power up the RSM and also to apply power to the seat motors when commanded. The RSM is grounded through the module ground circuit and G401.
The first place to start would be check the fuse's .Do you know where the left rear fuse block is located ? Fuse Block - Left Rear
In the passenger compartment, near the left side of the rear seat under the carpet
If the fuse is good next thing to do would be ,have check for DTC'S in the rear seat module ! This has nothing to do with check engine light or OBD 2 diagnostic trouble codes an a code reader for said OBD2 codes will not work . Would need a factory scan tool to check these codes.
DTC B1395
Battery positive voltage is supplied at all times to the rear seat load floor switch and the rear seat position switch by the rear seat module (RSM). The RSM monitors these battery positive voltage supply circuits for the protection of internal circuitry of the module.
DTC B1395 Device Voltage Reference Output 1 Circuit
DTC B1420 Device Voltage
Battery positive voltage is supplied at all times to the seat adjuster switch and the memory seat module (MSM) through the same circuit. The MSM uses this battery voltage input to determine if battery positive voltage is applied to the seat adjuster switch.
DTC B1545 Seat Stow Switch 1 Circuit
DTC B1546, Seat Stow Switch 2 Circuit
DTC B3729 Seat Recline Control Switch
DTC B1735 Seat Front Up Switch Circuit
DTC B1740 Seat Front Down Switch Circuit
DTC B1745 Seat Rear Up Switch Circuit
DTC B1750 Seat Rear Down Switch Circuit
DTC B1755 Seat Assembly Horizontal Forward Switch Circuit
DTC B1760 Seat Assembly Horizontal Rearward Switch Circuit
DTC B1815 Seat Recline Forward Switch Circuit
DTC B1820 Seat Recline Rearward Switch Circuit
Just from looking at the factory service info , I'd say you would be bet off just taking this to the dealer !
The first plase
5 Related Answers
Anonymous
  • Posted on Mar 24, 2009
SOURCE: third row seats
A little plastic bumper, located on a metal tab on the inside of the bottom seat cushions breaks off. It is supposed to hit the seat back release and allow the back to fold down when you push the bottom cusion in all the way. I finally just bent the metal tab up so it would hit the release and that fixed it. (Look for the broken palstic pieces under the seat cusion area as an indication) The dealer replaced the plastic part several times... a waste of time.
ourhowse
Dar
  • 2007 Answers
  • Posted on May 31, 2009
SOURCE: How do you remove the headrests on the front and third row seats?
There is a small hole at the base of the headrest post. Use a nail and push in the hole to release them.
Anonymous
  • 11896 Answers
  • Posted on Aug 24, 2009
SOURCE: need instructions to remove second and third row seats
On the bottom of the seats, there is a handle on each side. Lift up both handles at same time and have someone else lift up and pull out the back bottom of the seat and it will pull out.
Anonymous
  • Posted on Jan 17, 2010
SOURCE: third row seat in ford explorer stuck in down
my third seat is stuck in the down position . press switch to raise i hear the motor but nothing happens. 2006 ford explorer
Anonymous
  • 14 Answers
  • Posted on May 24, 2010
SOURCE: stow and go seat lock device broken
check for any recalls on the part first. the dealer may be your only option.
How do you remove the folded rear seats in a 2011 Cadillac SRX
There isn't much available on how to do that as they are not part of normal operation. My guess is that underneath you will find bolts that you will need a socket set to remove.
https://www.google.com/search?q=2011+Cadillac+SRX%2C+remove+folding+third+row+rear+seats
BROCKEN REAR FOLD DOWN SEAT LATCH CADILLAC SRX
i have a Cadillac srx, my 3rd row is now coming up can you help me. i tried the buttons, they make a beeping noise but the seat doesn't come up
Remove center seat belt in second row 2005 Cadillac srx
Remove the rear lower seat. Remove bolts holding belts to floor pan of vehicle.
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
Why is there no power to third row seat?
Power 3RD Row Seat Problems and Tranny Shutter - Ford Truck ...
www.ford-trucks.com > ... > Expedition & Navigator
Mar 27, 2014 - Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition andLincoln Navigator SPONSORED BY: ... First the 3RD row seats won't fold down, noclicking, no sounds, nothing. I the fuses are good and there is power at the fuse box, but no power at the motors or switches. Based on continuity ...
3rd row powerfold seat stuck down - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 2007 - 2014 Expedition & Navigator
Mar 14, 2010 - 3rd row powerfold seat stuck down 2007 - 2014 Expedition ... 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator ... I also tried lifting the seat while my wife was pushing the button to raise it, to no effect. There is defnitelypower going to the motor but it just isn't ... Join Date: Feb 2005.
No power to third row seat on 2005 lincoln navigator - Fixya
www.fixya.com/cars/t12295627-no_power_third_row_seat_2005_lincoln
Apr 4, 2012 - no power to third row seat on 2005 lincoln navigator third row seat is ... U will have to replace the entire power seat transmission, there is no ...
Lincoln Navigator Review - Edmunds.com
Stowaway seat will not operate
the stowaway third row seat on my 2006 Caddie SRX does not come down. when you press the switch it starts to move but then it goes half way and retracts back, as if something is catching. I also noticed that one side does not retract evenly with the other side. could it be the motor on that side is faulty?
Third row seat is stuck in mid position and will not open or close
This just happened to me today, did you get it resolved?
Mounting third row seat in 2008 Suburban 1FL, LS 1500 - Fleet veh
I drive a 2008 Suburban LT and my company has a true work "fleet" suburban. The only difference between these two that I have is the back of the fleet vehicle has a thick rubber mat in the back with no seats. After removing the black mat I found that the channels and rods that the rear seats clip into are present. The third row seats are installed by clipping them in no bolts or tools are required.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
