Question about Caterpillar Electrical Supplies
RPM Caterpillar generator not stable. Any solutions ? Thanks
    Top Expert:
  • Caterpillar Master
  • 53,745 Answers
Problem with the governor controls
if electronic controlled governor it could be the electronic system is faulty
If manual control , check for governor lever operation
check for fuel flow problems , blocked filters , low fuel level vent ing for the fuel tank blocked
Posted on May 28, 2016
2 Suggested Answers
SOURCE:
  • 53745 Answers
SOURCE: I have a perkins generator 120kw when it reaches 80kw the rpm dropes but at 50kw its stable what could be the problem ?
could be a problem with the condition of the motor ( do a compression check )
could be a governor problem in the fuel pump or possible a fuel delivery problem
check for a black slime in the fuel tank and if found clean out the entire fuel system, filters lines and with the new fuel use a diesel conditioner . if the fuel is clean then the problem will be in the fuel pump not giving full fuel to the injectors under load
if the engine rpms are electronically controlled ( throttle lever to electronic control) check that movement of the lever or the control unit
Posted on Jan 22, 2016
Low speed
Is your CHOKE still on? Is your Actuator Cable still connected?
Jul 03, 2014 | Caterpillar Electrical Supplies
My caterpillar gen electric gen set shown a fault alarm and emergency shut off after its not starting no any signal
What fault alarm did it indicate? No start signal at all normally means a safety lockout, is it cranking at all? Can you give me more details please
Oct 23, 2013 | Caterpillar 1984 3208 Generator Set 75,...
WHILE RUNNING SUDDENLY ENGINE STOP .THEN WE TRY TO START BUT NOT WORKING .WE CHECK INJECTOR IT IS WORKING .
There are more than one injector, did you check them all for fuel point of delivery? make sure cyl 1 is at point of delivery when flywheel is at delivery mark. Did it make a noise when it stopped? You may have lost a timing drive train? Has the fuel rack been shutdown due to a control signal? Please check these things, along with obvious sensor inputs
Aug 15, 2013 | Caterpillar D398 marine engine - 1200 rpm
Caterpillar 3412e valve lash adjustment
Contact JD Marine in Fort Lauderdale FL they can possibly get you the information, or sell you a service manual
Apr 03, 2013 | Caterpillar 3412E DITA Marine Propulsion...
Hard of starting
Possibly a mute quastion but did you check the engine block heater? WHy change the governor if it was calling for full fueling on cranking.
Mar 01, 2013 | Caterpillar 1978 3406, 3408, 3412...
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
Does anybody know where I can get a 3126 HEUI caterpillar engine tech manual, paper or cd/dvd version?
http://www.o2epc.com/Caterpillar-TRUCK-ENGINE-Service-Workshop-Manuals-2009-service-manual-Workshop-repair.html
not paper on cd 200bucks
Dec 17, 2009 | Electrical Supplies
RPM/voltage fluctuation on Guardian Primepact 50G
go to www.zabatt.com - look in their Service manuals section - good luck!!
May 28, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
238 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
ray gallant
ray gallant
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
