The chain came off while I was working. It is not broken. I opened the cover and put it back. but it is too loose. How do I tighten it. I have tried the screw on the side but it didn't help
You need a chain breaker tool to take a link out of the chain and that will make the chain shorter and then you can make the correct adjustment.
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
SOURCE: Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
SOURCE: how do i tighten my chain?
Mike's answer might do it. My saw has a feature in the Chain Bar to turn right or left to move the Bar in or out. Loosen those same nut Mike wrote about, but now turn the Bar Feature (gear) to adjust, and then tighten the two nuts.
SOURCE: poulan pro 20 chain wont stay tight
Take a link out of the chain. Had the exact same problem with my dad's chainsaw
SOURCE: need side cover over chain guard
The clutch cover and all attaching parts for a Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-1/75.2375LE-Gas-Saw-Type-1.1.59.1.html
on the "Handle, Chassis & Bar Assembly Type 1" drawing.
HTH
Lou
SOURCE: plastic housing broken due to over tightining
I call it a clutch cover, Poulan calls it a "Chain Brake Assembly", pn 545139903 for Type 1 or 2 - 2375 WildThing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Hi TAUSEEF, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Could you send me the brand name, the type, and the model number of your machine?
