Question about Canon imageCLASS D860 All-In-One Laser Printer
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
  • 92 Answers
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. I black_dot.gif If the paper is curled, uncurl it before placing iI am getting a supply Rec Paper Cassette alarm - black_dot.gifette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets I am getting a supply Rec Paper Cassette alarm - load_paper_in_cassette.gifaper.
  3. load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do I am getting a supply Rec Paper Cassette alarm - black_dot.gif a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert tI am getting a supply Rec Paper Cassette alarm - black_dot.gifs far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Posted on Jul 17, 2009
6ya staff
SOURCE:
"supply Rec Paper Cassette" canon L170
Tip up L170 and ensure paper detect flag is not broken or dislodged
Dec 06, 2012 | Canon Faxphone L170 Monochrome Laser Fax...
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
1,751 people viewed this question
Clive
Clive
old marine
old marine
Ekse
