Question about TCL L32D20
Why is tcl tv saying no signal and volume indicator keeps running back to zero?
After powering on, TV is saying no signal. Also after initially sending up the volume indicator via the remote control., it returned to zero on its own and refuses to go back up to 100 except when I depress the volume button at the back of the TV. however on releasing the pressure the indicator is again returning to zero on its own
5 Suggested Answers
SOURCE:
vinceisaac
  • 2432 Answers
SOURCE: tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Posted on Oct 14, 2012
  • 52420 Answers
SOURCE: tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Posted on Jan 25, 2014
hichbiri
  • 3469 Answers
SOURCE: why would it get hot once coex cable hooked up and scanning for channels? tv gets hot and shuts off.
I would check that there is not a problem with the power supply to the set. If it gets hot and shuts of the power may be faulty and could be causing component failure.
Posted on Jun 06, 2015
Testimonial: "I changed the mother board well the board with all the inputs"
  • 52420 Answers
SOURCE: the trouble of my tcl led tv was, everytime i use it, after several mins of watching, the tv turns off, even the standby light indicator turns off, what is the trouble of my tv?
Probably a failing power supply
Posted on Apr 08, 2016
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Tcl tv sound
New 48" TCL tv. Hooked into cable box via hdmi cable from hdmi 2 per instructions. Problem is no sound. Screen looks great volume bar shows volume etc. Any ideas before I take it back to SAMs.
Jan 05, 2014 | Televison & Video
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
'left' or 'volume down' function appears to be
The volume down button on front of TV is stuck down or the switch is bad.
May 02, 2010 | Televison & Video
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Jan 30, 2008 | Televison & Video
TCL L32D20 Logo
64 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
robert
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
