Question about Hyundai 2009 Santa Fe
Idle goes up and down in park and in drive.
Also when you are doing 40 to 45 mph feels like the engine is holding back.
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
Sounds like your EGR Valve (Exhaust Gas Recirculation). I had a 1995 Mazda MX3 and a 1998 Mazda Prot?g? that both had the same problem. The symptoms are as you described them. Check your vacuum lines for a leak first, they too can cause your idle to fluctuate, make your vehicle feel as though it's losing power (horse power) and make the vehicle feel as though it's going to stall when coming to a stop while you're applying the brakes.
Posted on May 28, 2016
    Top Expert:
  • Hyundai Master
  • 63,052 Answers
You need to get it serviced .
Posted on May 27, 2016
SOURCE:
What is the drive cycle for a 2003 Nissan Sentra SE?
Take extra caution while performing dirve cycles on public roadways. Drive cycles can be difficult to follow under normal driving conditions. Begin by: - Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on. - Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. - Hold at a steady speed of 55 mph for three minutes. - Decelerate (coast down) to 20 mph without braking or depressing the clutch. - Accelerate back to 55 to 60 mph at ¾ throttle. - Hold at a steady speed of 55 to 60 mph for five minutes. - Decelerate (coast down) to a stop without braking. If all other emissions systems are functioning properly, completing the drive cycle above will set the "readiness flags" required to pass the smog check. It will not hurt to perform the drive cycle 2 or 3 times before the smog test.
Oct 06, 2016 | 2003 Nissan Sentra
Toyota corolla hatch 2002 idle at 2000 rpm when
All the above is normal , except 2000rpm is a little high at idle . can be adjusted down to 1500rpm. the computer adjusts the engine speed . in drive the transmission loads up the engine idle drops to 1000rpm . in park engine unloaded rpm increase all normal.
Sep 17, 2014 | Cars & Trucks
I have a 99 chevy malibu with roughlt 220 thousand miles... make a long story short I was in a fender bender at about 25 mph. Minor. Impact front left panel. Completely drivable from the scene. Well I only...
Sounds like maybe a motor mount may have broken,if you
open the hood and put the car in drive ,then neutral then reverse
the engine should only "rock" about an inch or so,if it really jumps
that is the problem.
Feb 26, 2013 | Cars & Trucks
Drive cycle
Here is the OBD2 emission system drive cycle test procedure.
Engine coolant temp must be below 70c (158f) before starting the engine for either the first or second trip
The fuel level should be less than 1/2 full
First trip:
Start engine, idle for at least 1.5 minutes
Drive 3 minutes, hold b/f schdl: 1.5-2.0 msec, selector lever "3rd" eng rpm 1,800-2,000 A/C switch:ON Hold the recommended b/f schdl range. Allow road speed to vary as necessary.
Drive at 55-65 mph for 1.5 min b/f schdl 2.0-3.2 msec, selector lever "5th" Engine rpm 2,200-3,000
IGN "off" for at least 10 seconds (not more than 5 min)
Dive at 50-60 mph for 3 minutes Selector lever "4th" keep engine speed above 3,000 rpm Allow speed to vary if necessary. Do not decelerate for more than 3 consecutive seconds. A/C switch ON.
Drive at a steady state cruise of 53-58mhp b/f schdl more than 1.8 msec selector lever "5th" eng rpm 2,400-2,600
Downshift to "4th" and decel more than 5 seconds without breaking, then idle for 1 minute.
Drive two minutes b/f schdl less than 2.0 msec Accelerate to 41 mph, decelerate to 34 mph, accelerate to 41mph. Do not completely release the accelerator. A/C switch off.
Idle 1 minute in park or neutral
Drive two minutes Steady state cruise at 31-44 mph. Selector lever "4th" A/C switch OFF. Hold the accelerator pedal as steady as possible. Allow speed to change if necessary.
End of first trip. Turn the key off the begin the second trip.
Second trip:
IGN "off" add four gallons of fuel
Drive two minutes Steady state cruise at 31-44 mph. Selector lever "4th" A/C switch OFF. Hold the accelerator pedal as steady as possible. Allow speed to change if necessary. I especially like the part where they want you to add four gallons of fuel. Not three gallons, not five gallons, four gallons. Gotta love those Nissan engineers. ...and of course they state that if the trace is not followed exactly (i.e. you botch the acceleration/deceleration) you have to start all over again from scratch
Feb 09, 2012 | 1996 Nissan Pickup
Start car and the idle goes to 3000 rpm, holds there for around 12 seconds or so and then comes down to around 1200. when driving if stopped and you put the car in park or nuetral the idle will go up to...
it sounds like a vacuum leak to me, my car had the same problem but when i changed the hose that connected the valve cover to the fuel injectors the rpms dropped back down to about 800 rpms
Sep 17, 2010 | 1999 Saturn SL
How do i do the drive cycle on a 1997 nissan pathfinder
The following drive cycle can be used as a guide to assist with re-setting monitors when a vehicle specific drive cycle cannot be located. This OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another). This condition can be achieved by allowing the vehicle to "sit" overnight, and then by beginning the drive cycle the next day. Most drive cycles will be difficult to follow exactly under normal driving conditions, so the driver should exercise caution, road safety, and courtesy to others.
  1. . Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on.
  2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle.
  3. Hold at a steady speed of 55 mph for three minutes.
  4. Decelerate (coast down) to 20 mph without braking or depressing the clutch.
  5. Accelerate back to 55 to 60 mph at ¾ throttle.
  6. Hold at a steady speed of 55 to 60 mph for five minutes.
  7. Decelerate (coast down) to a stop without braking.
Sep 17, 2010 | 1997 Nissan Pathfinder
Tach. drop's to zero while driving 70 ?
I have had the almost same problem twice. A 'thump', like the engine missed a fire and tach drops. Seems OK after restart. Electrical? Timing chain slip?
Has 135,000 mile. Any clues?
May 15, 2010 | 1997 Buick Park Avenue
Vibration when idling and between 40-70 mph
check out harmonic balancer .
May 26, 2009 | 2002 Audi A4
Hyundai 2009 Santa Fe Logo
48 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
moony
Level 1 Expert
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
