Most machines with a bobbin winder on them have a round knob inside of the machines flywheel. That's the wheel that turns when you sew.
TURN the inside knob forward or reverse to lock or unlock the main gears from turning the needle bar in the sewing motion.
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
change the needle--needle must be correct one for fabric sewn adjust the top tension--make sure there is no lint or loose threads in the top tension dial also clean under the needle plate & in the bobbin area for lint or loose threads make sure the bobbin is inserted correctly--some bobbins only go one way
the up and down buttons are not working properly. When pressing the needle down button, the needle does go down and then comes right back up. pressing the needle up button makes the needle shoot up and down 2 times very fast. HELP
