Heating & Cooling Logo
j
jose Posted on May 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my ac not blow cold air?
The indoor unit only blows warm air. the out side unit sounds like the compressor kicks on , but i noticed that the outside unit condensers don't get warm at all.
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Jun 04, 2016
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1250650
Points
7008
The air blowing out of the condenser should be warmer than the ambient temperature , provided the compressor is running. If compressor running but no warm air, you are likely out of refrigerant. Check the larger of the 2 copper lines at condenser, it should be cool and sweating like a glass of ice water. I've not, likely low refrigerant.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
MightyMikeJr
Level 3:
Master:
  • Master 409 Answers
  • Posted on Jun 02, 2016
MightyMikeJr
Master
Level 3:
Master:
Answers
409
Questions
0
Helped
313691
Points
1250
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
5 Related Answers
Anonymous
  • 400 Answers
  • Posted on May 08, 2009
SOURCE: 2000 isuzu rodeo, ac blows
You may have a clogged expansion valve.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 06, 2009
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Anonymous
  • 158 Answers
  • Posted on Aug 01, 2009
SOURCE: the unit only blows warm air. it just stopped
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Anonymous
  • 614 Answers
  • Posted on Aug 15, 2009
SOURCE: ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
christian nielsen
  • 358 Answers
  • Posted on Aug 30, 2009
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
AC blows warm air. 07 GMC Envoy 6 cyl. 4wd
You probably replace the wrong switch. I believe the high pressure switch is mounted in the back of the compressor. Pull the plug and jump it. If it works, replace the switch. I don't recommend you leave the jumper in the plug. If it the A/C pressure is to high, you could blow lines and such. Costing you a lot of money.
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
A/c and heater problem A/C will sometimes blow cold air for about 20 seconds then start blowing warm air. Then when using the heater it will blow warm air for about 20 seconds or so then start blowing cool...
sounds like you may have developed a leak in the system, when the pressure in the system is low it will cause the compressor to cycle off and on. Have you tried to charge the system? P.S. Dont know if you are aware but hte compressor kicks on when the heat is on as well as he AC.I hope this helps and good luck !!
2answers
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
4helpful
2answers
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
4helpful
3answers
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Top Heating & Cooling Experts
Paul Carew
john h
