My contractor installed a 24" Rockland towel bar. I now want to remove it so that I can paint the wall. I can't find the instructions, and I can't remove the towel bar.
On both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Do the tips come off? Is it possible that the bar slides through the brackets? Most high end hardware has very small Allen screws to mount it. If not, go to Moen website for instructions or a phone number
The base is probably connected to wall with toggle bolts, thus meaning , as you try to unscrew the bolts that keep spinning, pull on the bracket away from wall as you unscrew the bolts and it will come off.
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Sorry to read about your problem, I hope this helps you out.
remove the setscrew.. your paint must be holding it on...put a knife and pry a little
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete)
Here is a couple of videos that should help understand how towel bars
First off you need to pry off the cap thats facing you (most models). Then there should be a little hole on the side for each one that needs an allen wrench to unscrew off the wall.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Towel bars usually have a base that attaches to the wall with a screw. To expose the screw, you must loosen and or remove a small screw on the underside of the mounts. Once the screw is exposed just tighten it.
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
