India
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: Konica Minolta bizhub 163 Display
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
SOURCE: Konica Minolta bizhub 210 error m2 appear on
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
SOURCE: proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
