SOURCE: Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
SOURCE: 1988 johnson trim wont go up or down replaced relays still wont work
Try going directly to the trim pump with 12 volts bypassing the solenoids, go directly to the green and blue wires, disconnect the relays first, see if it works, if it does, your problem is before the motor, if it doesnt your problem could be bad or dirty brushes in the trim pump motor which usually can be fixed on the cheap !
