SOURCE: motorola h700 ear piece
Try 1234....hope this helps...I believe someone else in here tried that code and it worked.
Good Luck
SOURCE: Ear piece does not work. Station top light does not come on
Did the earpiece battery run down? If it did, the base will lose the connection. Does the red light on the left on the holder flash?
Ensure you have charged the earpiece and turn it on ... once the earpiece is flashing blue, I've found it take about 30-45 seconds for the base to pick it up and pair again.
You'll know it found it when the red light becomes solid and the blue upper light glows.
SOURCE: Need help with Case Logic bluetooth ear piece model BTH-10
The generic PIN for that bluetooth is : 1234
Good luck
SOURCE: accidently deleted ear piece and now my storm cant
Do you still have your charger cradle? Try putting in the number that's bolded on the bottom of the case. Mine is a twelve digit number and it is the pin number that your phone is looking for. At least it was for mine.
SOURCE: how do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
