No app on tablet. Tablet has been reset and still says there is same name app on tablet when everything has been removed help please
SOURCE: How do i copy .apk apps from my computer to my
Just use the provided USB cable and connect the tablet to PC. Windows will recognize it as another drive (USB Mass Storage similar as USB HDDs and USB sticks). Copy the APK file anywhere (for example to Downloads folder. Then unplug from PC and run the Files application on Archos. Browse to the directory and clicking on the APK filewill start installation process.
Testimonial: "Thanks, was easy to figure out compared to my friends Kyros. Even got that GAppsInstaller .apk installed..."
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: can not download apps to a 4sight tablet
Check out:
http://slideme.org/
http://www.freewarelovers.com/android
SOURCE: Hi I just got a tablet online and it doesn't have
Just make sure with the play store settings, whether you have sign in with your G mail account or not. If no just sign in and try else register as a new user and try. If found still there were an error. Just try to restore the tablet. If you again found the same error then, shutdown the tablet and press power + volume up button up to 15 seconds, so that you will get restore option there and restore through that. Definitely it will work for you.
