Tip & How-To about Schwinn Airdyne Exercise Bike
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
Schwinn Airdyne Exercise Bike Logo
what sort of tool is needed to change the chain on a schwinn meridian adult trike?
Find the master link first. It will be the only one without the hourglass shape (flat on the sides) I just use a needle nose or a screw driver and a light tap with a hammer using the screw driver as a wedge. Using this method make sure to keep your eye on the master if it flies off.
How to tighten chain on schwinn airdyne evo
if you do not have the instruction manual section troubleshooting, download for free in www.fitness.manualsonline.com or www.iconservice.com and proceed the instruction for fix it.
God bless you
im trying to take the chain off my 1969 schwinn stingray 20" fastback 5-speed bike and i cant find a master link,how do i get it off,please help,thanks Duane
Duane,
Not all chains have a master link. You need a chain tool that presses a pin out. They aren't expensive and come with instructions. Any bike shop will have one. Take a look here for info:
http://www.parktool.com/category/chain
Park tools are excellent quality at reasonable prices, but there are others. And if the tool says it's for derailer chain, it will still work for a single-speed chain.
Schwinn Stingray Chopper master link on chain
look for adifferent looking link more oval than the rest it is also possible that there is no master link that the chain was joined with a chain tool especailly if is a multi speed bike with a derailleur
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
