Question about Joal 1/32 Komatsu PC 450 LC-6 Excavator
ERROR CODE DHH4KA FOR KOMATSU D155AX-5
48W45017 ENGINE
    Top Expert:
  • Joal Master
  • 85,020 Answers
Duplicate
Posted on May 23, 2016
SOURCE:
01 Cadillac overheating and having no power like it has a governor on it
The engine is swelling because of the over heating. Stop using it !!!!!!!!! Gotta fix cooling system lest you seize the engine.
Nov 11, 2015 | Cadillac Cars & Trucks
Tip
What you need to know about Hyundai
I am a mechanic ..most people ask questions about these foreign hyundai motors ..below is an example of engines that basically if you ask about a Hyundai Xg 350 ,xg300 ..well allow me to hammer 90% of your questions in case you want to grab another motor ..these motors listed will work on 90% of all hyundai products ...Look at the starter sizes ,,all the same for the selected models ..then look at the motor sizes ..This will help you in solving some problems most do not give the specific questioning
100% NEW REPLACEMENT STARTER
FOR
STARTER
12 VOLT / CW ROTATION / 8 TOOTH DRIVE
REPLACES:
MANDO M62957
VALEO TM000A14401
BOSCH REMAN SR4118X
BOSCH NEWMAN SR4118N
HYUNDAI 36100-37210
FITS ON:
HYUNDAI
2001 SANTA FE 2.7L ENGINE
2002 SANTA FE 2.7L ENGINE
2003 SANTA FE 2.7L ENGINE
2004 SANTA FE 2.7L ENGINE
2005 SANTA FE 2.7L ENGINE
2006 SANTA FE 2.7L ENGINE
2003 SANTA FE 3.5L ENGINE
2004 SANTA FE 3.5L ENGINE
2005 SANTA FE 3.5L ENGINE
2006 SANTA FE 3.5L ENGINE
2002 SONATA 2.7L ENGINE
2003 SONATA 2.7L ENGINE
2004 SONATA 2.7L ENGINE
2005 SONATA 2.7L ENGINE
1999 SONATA 2.5L ENGINE
2000 SONATA 2.5L ENGINE
2001 SONATA 2.5L ENGINE
2003-2008 TIBURON 2.7L ENGINE
2005-2008 TUCSON 2.7L ENGINE
2001 XG300 3.0L ENGINE
2002 XG350 3.5L ENGINE
2003 XG350 3.5L ENGINE
2004 XG350 3.5L ENGINE
2005 XG350 3.5L ENGINE
KIA
2004 AMANTI 3.5L ENGINE
2005 AMANTI 3.5L ENGINE
2006 AMANTI 3.5L ENGINE
2001 MAGENTIS 2.5L ENGINE
2002-2006 MAGENTIS 2.7L ENGINE
2001 OPTIMA 2.5L ENGINE
2002 OPTIMA 2.7L ENGINE
2003 OPTIMA 2.7L ENGINE
2004 OPTIMA 2.7L ENGINE
2005 OPTIMA 2.7L ENGINE
2006 OPTIMA 2.7L ENGINE
2002-2005 SEDONA 3.5L ENGINE
2005 SPORTAGE 2.7L ENGINE
2006 SPORTAGE 2.7L ENGINE
2007 SPORTAGE 2.7L ENGINE
2008 SPORTAGE 2.7L ENGINE
on Oct 24, 2013 | Hyundai Cars & Trucks
How to oil pan out
what engine type if you have the 3.4 engine you need a engine lift or engine support fixture you have to remove engine mount and engine mount bracket.also 3.8 engine you need engine lift to raise engine to remove engine mounting bolts.
Feb 09, 2013 | 2000 Oldsmobile Silhouette
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
What type of oil and how much do I use with the honeywell 1000w generator?
Engine Oil Recommendations
Use 4-stroke oil, or equivalent high detergent, premium
quality motor oil certified to meet or exceed U.S. automobile
manufacturer's requirements for API Performance
Class SF or better. SAE 15W-40 is recommended for general,
all-temperature use.
NOTICE
Engine oil is a major factor affecting engine performance
and service life. Non-detergent and 2-stroke engine oils will
damage engine and are not recommended.
• Be sure to use engine oils specified under "Engine Oil
Recommendations."
It is very important to maintain proper level of engine oil to
keep engine in good running condition.
• Check engine oil level prior to each use. Refill engine
oil if oil level is low.
FIGURE 17: Recommended Oil Viscosity
Crankcase pressure can cause hot engine oil to
spray out of engine fill hole. Hot engine oil can
cause severe burns.
• ALWAYS stop engine before removing the oil fill cap.
15W-40
WARNING
FIGURE 18: Oil Fill Cap Removal
FIGURE 19: Oil Fill Measurement
Oil Capacity [qt / ml]
HW1000i 0.26 / 250
HW2000i 0.48 / 450
TABLE 4. Engine Oil Capacity
Mar 08, 2011 | Garden
Trouble locating cooling sensor on 2003 gmc envoy
4.2L Engine To Remove:
  1. Disconnect the negative battery cable from the battery.
  2. Drain the coolant from the engine.
  3. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation gm-04-42-1509.gif
  4. Remove the engine coolant temperature (ECT) sensor from the engine.
To Install:
  1. Apply thread sealer P/N 12346004 or equivalent to the engine coolant temperature (ECT) sensor threads.
  2. Install the engine coolant temperature (ECT) sensor into the engine. Torque the sensor to 12 ft-lb (16 Nm).
  3. Connect the engine coolant temperature (ECT) sensor connector.
  4. Refill the engine with coolant.
  5. Connect the negative battery cable to the battery.
5.3L & 6.0L Engines To Remove:
  1. Drain the coolant from the engine.
  2. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation removeect.gif
  3. Remove the engine coolant temperature (ECT) sensor from the left cylinder head.
To Install:
  2. Install the engine coolant temperature (ECT) sensor into the left cylinder head. Torque the sensor to 15 ft-lb (20 Nm).
Jul 08, 2010 | 2003 GMC Envoy
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Joal 1/32 Komatsu PC 450 LC-6 Excavator Logo
228 people viewed this question
Top Joal Toys Experts
Marvin
Marvin
qumozheklj
qumozheklj
Level 1 Expert
Bill Boyd
Are you a Joal Toy Expert? Answer questions, earn points and help others
