This unit should have a defrost timer on near the compressor. You can turn the dial so it is the area set for defrost time. Usually times are set for 6 am, 12 pm, 6 pm 12 am for around 30 minutes. Adjust the timer dial to where the screw is. Or you can just unplug it.
I would check your defrost timer to see if it is rotating. It may be stuck in defrost mode. you can check this by manually rotating the timer dial CCW yourself. This will be located in the front bottom left had corner behind the vent panel.
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed. If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer. It is probably on the rear near the compressor. Some are under the front behind the dust guard.
On my upright freezer I use pans or trays I have and set them in the bottom where it catches nearly all the water. I don't have to empty them till it's all melted because it till hold all of it.
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
• 0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
• 1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work.if it is staying in defrost their is a manual stem you have to turn.Tom
Check the defrost timer for operation if your unit has one. Some Delfield models have solid state controls. If your system has a timer for the defrost you can open the timer cover and turn the dial in the direction indicated by the arrow until a time peg comes up to the time of day marker. You will hear a loud click and the compressor will shut off. Defrost should take place. The inner dial of the timer will have some indication as to how long in minutes the defrost should take. If the pointer does not move while in the defrost position the timer motor is bad. Turn the dial again so the copper pointer goes past the time of day marker and the compressor should restart. Replace the timer.
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
