To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled. KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
on a Kodak dx6490 - you will need to go into the menu, choose the time stamp icon, then choose whether you want yy/mm/dd, or dd/mm/yy, or mm/dd/yy.
if you turn off the time stamp , you must choose one of the above options before it will turn on again. hope this helps 8^)
The date stamp only works in "Postcard" resolution. Press the Func Set button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. The date time stamp selection should now work. Simply turn it on.
I had the same problem. I wanted to set my Olympus C5000 Zoom to automatically date stamp photos. After going through the entire manual, I had to call Olympus directly. They told me that none of their cameras have an internal date stamp feature. They said that the date stamp lowers the quality of the picture, so they choose not to have the feature available. However, you can manually add the date and time stamp through the software that comes with the camera, just before you print the pictures. Hope that helps...
if you need help with that manual go to http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/ and get our off the list. It is on there!!! about the middle of the page.
The time/date is 'stamped' onto the video during recording. The time/date stamp function can be turned on or off in the setup menu. If it was 'on' during recording, it will be displayed when played back. If it was turned off, it will not be seen on the recording.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
