To turn off the Pelican Sabrelite 2000 flashlight, you will need to locate the switch or button on the flashlight that controls the power.
On most models of the Pelican Sabrelite 2000, the power switch is located on the tail cap of the flashlight, near the base. To turn off the flashlight, you will need to press and hold the power switch for a few seconds until the light turns off.
If you are unable to locate the power switch or if the flashlight is not turning off as expected, you may need to refer to the owner's manual for your specific model of Pelican Sabrelite 2000. The manual should provide information on the location and operation of the power switch and any other controls on the flashlight.
If you are unable to find the owner's manual or if you are still having trouble turning off the flashlight, you may need to seek further assistance from the manufacturer or a technical support professional. They will be able to provide you with more information on how to operate your specific model of Pelican Sabrelite 2000.
The top of the battery nearest the light bulb is the positive connection and is in direct contact with the bulb. The negative connection is a strip of brass that runs along the length of the torch from the bottom (bottom of last battery) to the bulbs side connection.
Unlike conventional incandescent flashlights, where the bulb unscrews or pops out of the reflector assembly for replacement, the Pelican Sabrelite bulb is permanently mounted in the larger assembly. The entire "lamp module" is replaced as a single unit.
Replacement lamp modules can be found on the Internet and at some outdoors stores. For example, Amazon.com sells these, both individually and in 2-packs. Prices vary depending on the website, but just now, I saw them in several places for under $9/each.
hi dirtrider,
The ive used many fans such as the interloper, and they all were faulty, didnt work very well, and some were extremly loud.
The pelican, although, is what I us now, and I have yet to find anything wrong with it, the looks are kinda weird but its worth it, also rememberto turn the fan on/off at the right times, because its powered by usb, and theres power feeding through it constantly while its turned on.
Good luck, and happ gaming.
