Plumbing Logo
Dave Venning Posted on May 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When switched to filtered water on my kitchen faucet water comes out of both sides like the switch isn't working brand new filter on 1year old unit?
Ron F
Level 2:
Novelist:
  • Expert 135 Answers
  • Posted on May 21, 2016
Ron F
Expert
Level 2:
Novelist:
Answers
135
Questions
0
Helped
46757
Points
303
Sorry, these thing are often more trouble than they are worth. Without naming names, even the best of the best have seal and valve issues over an unreasonably short period of time. While they are quick and easy to install compared to a plumbed in model, they eventually leak from somewhere, the faucet, the filter cover, or, like yours, the cut-over valve.
You can, keep spending money on replacements, have a dedicated filter plumbed in, or resort to bottled water, all of which run the cost of purified water up beyond the price of tap water.
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Anonymous
  • 14 Answers
  • Posted on Dec 27, 2008
SOURCE: Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
Anonymous
  • 34 Answers
  • Posted on Feb 04, 2009
SOURCE: water is plugged by minerals etc in my Hansgrohe kitchen faucet
You will need a flat head or a knife. You sould be able to pry it apart if not they are so cheap, pick one up at walmart, lowes etc. Bring the old one with you. Some of the tread patterns are diffrent
Anonymous
  • Posted on Apr 05, 2010
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
We flushed our hot water tank and after that we have very little pressure our 122-426 b&K kitchen faucet. Changed the cartridge and cleaned the aerator
There's a little filter in faucet head and it may have got backed up with calcium from old water heater when changed.. U can just pop it out with lil knife and then run faucet with hot water to get any build up.. U can pick up more screen filters at local hardware store for cheap..
Jul 27, 2013 • Plumbing
Aqua clear system. no water is coming out of the aqua clear faucet and the water and ice are not working in the refrigerator, the tank is empty
First make sure you are getting water to the unit. There should be an 1/8" line supplying water to the unit on the back side and the line may be bent or kinked. If there is a good water supply then the next thing to check is the inline filter if it has one or it may have an internal filter system, check it. If at this point you are still not getting water then it will be in the electrical system ie: the solenoid switch that opens and closes the water supply for the ice maker.
Now you have said that you are not even getting water to the faucet so I would go with the water supply problems as being the problem.
Today,water was coming out of faucet but will now only come out of the sprayer and nothing out of the faucet. This has happened a couple of times recently but "self-corrected". The faucet is 6 years old.
Hi, there are filters that need cleaning periodically. Undo the nut where the water comes out from the tap, use an appropriate sized spanner, remove meshed filter, clean under running water and replace.
Hope this helps
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
2helpful
Kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
2answers
Bad taste and smell in water at kitchen sink faucet
Check your water filter inside the unit up in either the left or right side of the top. If you do not have a filter then add a filter to the unit on the supply line to help with this problem
2answers
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
18helpful
4answers
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
