have you tried entering your backup pin? if you fail to enter you pattern, you have the option to enter a backup pin. Usually by default, the pin is the last 4 of your phone number, or maybe something like 0000. But if you do know your pin, just enter that to log in
This is a security feature.. You should be glad. If your phone was stolen this is what the thief would be dealing with. Why not sign into your google acct and answer your secure questions and reset your lock pattern? An ATM uses a similar feature referred to as 3-strikes you're out. After 3 unsuccessful PIN attempts your card is history. I don't know any way around this feature but maybe another 'fixer' can help. And I wish you luck
you have entered the wrong unlock pattern to unlock your phone. at this point it may have a countdown when it's gonna let you try again or it may let you try and unlock using your email address or a backup pin number. not really sure what to tell you because you did not say what kind of phone it is.
If you have forgotten the screen unlock pattern, you have up to five attempts to try
and unlock your phone. If this fails, you can unlock HTC Inspire 4G by entering your
Google Account user name and password.
On the unlock screen, attempt to enter your unlock pattern five times.
When prompted to wait for 30 seconds, tap OK.
If the display goes off, press the POWER button to turn
the display back on, and then press the bar on the lock screen and slide your
finger down to unlock the screen.
Tap the Forgot Pattern button in the lower right corner
when it appears.
Enter your Google Account name and password, and then tap Sign
in.
You are then prompted to create a new screen unlock pattern. If you no longer want
to use a screen unlock pattern to secure your phone, tap
Cancel. Follow that instruction step by step and if you success you get your HTC unlocked, remember read that instruction carefully, if you did wrong step you will not allowed to enter your google account.
and unlock your phone. If this fails, you can unlock your phone by entering your
when it appears.
in.
Tounlock cell phone Password:Instructions Things You'llNeed:
Enter the last fourdigits of your phone number on your cell phone PIN screen.
Enter 9999, and if thatdoesn't work try 1111, and if that doesn't work try other 4 digit numbers youmay have entered.
Shut off your cell phone,take off the back of your phone and pull out the battery. Record the IMEInumber which is under the battery. Re-insert the battery and power on thephone. Enter the last 4 digits of the IMEI number on the PIN entry screen.
Call your serviceprovider and request the unlock PIN. You will have to prove you are a customerby stating your cell phone number, address and social security number.
5
Turn off your phone. Holdthe keys "3," "*" and "Call" and switch the phoneon. Hold the three buttons down until the word "Formatting..."appears on the screen. This should reset the phone lock code.
After 5 failed attempts to unlock you should be presented with a button in the lower left of the unlock screen labeled 'Forgot Pattern?'. hit this button and enter your Google account credentials you used to initially sync the device with your Google account.
Cheers,
immorion
