Question about LeapFrog Video Game Consoles & Games
Bought Used Leapfrog Epic on Ebay in Excellent Condition but has Parental Lock !
How do I bypass and set up new Parental Code ?
  • LeapFrog Master
  • 26,353 Answers
You need to do a Full Factory Reset from a computer that has Leapfrog Connect software downloaded to it. You can't do this from the device itself. It is a master reset which removes the operating system and reloads a fresh version.
https://www.youtube.com/watch?reload=9&v=mAICHprrxZk
https://www.google.com/search?safe=off&ei=mnxsXNbPM7COgge5u774Dg&q=leapfrog+epic+reset+&oq=leapfrog+epic+reset
Posted on Feb 19, 2019
  • 2 more comments
  • Jodi Hewitt
    Jodi Hewitt Feb 20, 2019
    You have to have a parent code to get in to reset to factory settings that way, and I do not have the parent code it was a returned merchandise.
  • Jane Arsenal
    Jane Arsenal Feb 20, 2019
    Did you ever figure this out? I too have a used Leapfrog with the same problem
  • Andrew Taylor
    Andrew Taylor Feb 20, 2019
    There appears to be two different issues. Yes, you need the parental code to reset the parental code or turn it off. This is done from the device itself.
    The video shows how to do a full master reset and scrub the whole thing clean to an as new state. you have to use a computer to do this and you have to download Leapfrog Connect software. Set up your account and then click RESET on the connected device which scrubs EVERYTHING on the unit and reloads a clean operating system.
    I did watch the video and a code was not mentioned.
    If that really doesn't work, phone Leapfrog direct, but I am sure I am correct in my answer to you all.
  • Andrew Taylor
    Did it work ladies? Please let me know if you tried it. The feedback helps others and builds my own knowledge base :>)
SOURCE:
SOURCE: PS2 parental control
press select enter 7444 and then it will promt youto enter a new password
Posted on Jun 03, 2008
SOURCE: PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Posted on Dec 07, 2008
  • 273 Answers
SOURCE: Playstation 2 was bought used, has a parental lock, can't turnoff
try this:
press 'select' button-->enter 7444--> enter new pass code-->
-->re-enter new pass code
movie should start
Posted on Aug 07, 2009
  • 161 Answers
SOURCE: bought a used playstation 2-need to get parental
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
If this does not work, the other code is usually 0000. However if they change the default password, then it will be hard to find out.
Posted on Sep 10, 2009
SOURCE: I bought used Nintendo DSi on ebay and is locked -
Problem solved. Call Nintendo services 1-800-255-3700, reset a master key, fast and easy solution!
Posted on Feb 06, 2010
Testimonial: "A+++++++++++!"
How do i reset the parent passcode on my daughters leappad ultra
If you forgot the parent passcode/lock code you can reset it by following these instructions: Forgot Parent Lock code on LeapPad
Apr 10, 2016 | LeapFrog LeapPad Ultra Learning Tablet -...
Forgot password to leappad ultra tablet unable to access parent user account
Forgot Parent Lock code on LeapPad Published 07/10/2013 01:47 PM ' Updated 06/15/2015 04:11 PM
I forgot my Parent Lock code, how can I access parent settings on the LeapPad3, LeapPad Ultra, or LeapPad Platinum?If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
Answers others found helpful
Apr 19, 2014 | LeapFrog LeapPad Ultra Learning Tablet -...
LF.com ParentAccount instead
How do I obtain a parent code for my child's leap pad ultra? My child started the ultra before I could set up anything.
Dec 29, 2013 | LeapFrog LeapPad2 Explorer - Green
Parental contolled locked. I bought a used xbox and I need to reset the parental controls to play video games.
GA_googleFillSlot("TL-IMU-Article"); reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
Thanks Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 10, 2010 | Microsoft Xbox Console
try this:
movie should start
Aug 02, 2009 | Sony PlayStation 2 (PS2) Console
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Parental control
hi crakmonk
At the screen where it ask you to imput the password enter 7444. the old password will be deleted and you will have to setup an new one.
Just leave it blank to not have a password setup.
or look here for more info Open Tech Support - Playstation 2 Parental Control Reset/Bypass
riz.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
Overriding parental block code
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
May 24, 2008 | Televison & Video
Video Game Consoles & Games Logo
838 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
syaiful ridlo
syaiful ridlo
Vladimir Frolov
Morgan T Bradshaw
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
