The top rack/basket rolls out fully when door is opened, Can this be adjusted some way? Is the entire unit not leveled properly? Have had no problem with it for years. I replaced the two small plastic end cap things on the front and back of both sliding roller bearing units with no effect.
SOURCE: Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
SOURCE: The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
