Televison & Video Logo
L
Lester E Slough Posted on May 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix my Samsung LCD TV?
My tv will not turn on stand by light blinks 5 times and repeats. When I disconnect evolution kit standby light does not blink, it goes off and power light bottom center comes on. I read a blog where the guy had a different model but same problem and his turned out to be main board. Please help.
Grubhead
Level 3:
  • Samsung Master 5,755 Answers
  • Posted on May 19, 2016
 Grubhead
Samsung Master
Level 3:
Answers
5755
Questions
Helped
1660113
Points
11417
It rather seems to depend on the model. I have seen Two videos on YouTube, one says it could be the LED back lighter, with a burned or shorted out LED(s). In the other it says it is the power supply board. But both were different Samsung TV's. The LED one if that looks tricky to do. If it is the power board, which I think it could be, you should be able to get the full board fairly cheap. Just be careful with the voltages when removing it, if you intend to do it yourself.
To see the Videos just type "Samsung TV blinking lights" into YouTube.
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
3answers
How do i fix a plasma Samsung tv
Tony, need some info for help like model number, age of set, can u unplug for 10 min. then turn back on, and since u have taken back off what have u tested or looked at?
My standby light blinks three times but tv never comes on
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
1helpful
2answers
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
5helpful
2answers
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
4helpful
2answers
My SONY HD projection TV KDP-51WS550 (2005) suddenly lost the picture and the Stand By /Timer light starting flashing 5x and then repeating. The next morning the TV came on and the flashing stopped. Turned...
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
2answers
Sony WEGA Trinitron SRS BBE 32'
Please reply couple of questions about TV to guess what could be wrong.
1- How many times standby light blinks, there would be interval of 3 seconds in blinks so count pause to pause.
2- Please intimate exact model of TV, written on sticker pasted at back of TV. That will help me to check its schematics.
Hit " add a comment" button to reply.
Thanks.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
7helpful
3answers
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
