Have to unplug for it to shut off when water trigger is released
Sharon, you first should make sure you have no connection/leaks any where. There is a pressure switch inside the pump, which controls when the motor turns on and off. Leaks in pressure causes the pressure switch to activate the motor. Leaks are the biggest contributor to a cycling machine. If no leaks, the pressure switch is defective. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Karcher North America Home Garden Online Help
Frequently Asked Questions about Pressure Washers
Common Pressure Washer Repair Problems Pressure Cleaned
