There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
One question. Were you able to move apps to the sd card before?
When you go to settings, storage, does it show the external sd card? I want to explain something first. The sd card is an expandable storage card, but it won't store your apps. If you want to check it out just insert the old memory card in a computer and look for any apps. Smartphones usually comes equip with 2 types of storage:
1. Internal phone memory: which could range from 500mb. to 2gb. of storage. This will be by default the location where the apps would be saved.
2. Internal SD Card: this is an expand storage that is already in the smartphone. Notice that when you see an ad for the phone it usually advertise whether it is 4, 8 or 16gb. That is the internal SD storage.
The third option is the external micro sd card, which is the one you are having problem with.
In storage under settings, see if you have an option to mount the sd card, maybe it's not mounted. You can also clon or copy everything from the old sd card to the new sd card using a computer, and then try it again.
Go to previous view pics in internal memory, select the pic and then "move"at SD Card (work in some models).
Other possibilitie, take off the SD card and connected the camera at pc, open explorer software and copy/paste the pics from camera at one folder in the pc. Verify that the pics are saved and secure, so, delete the files in the internal memory. Turn off and unplugged the camera.
Then, take on SD card inside camera and reverse procedure, copy/paste from pc to SD card (like a external device).
You didn't specify what type of card, so I'll assume it's either an SD or an SDHC card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
File Manager will work (Start -> File Manager). I use Total Command as opposed to file manager. There is also a setting to default your (future) pics to the SD card. Hit the camera button, hit Menu (right soft button), select Options... select Camera, then Save Files to.
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
