Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
