If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
It looks like a Samsung Oven and the E08 is a preheating error It could be a relay or a defective Thermostat. If U have food in the Oven during the preheating that can cause the error as well...
The error occurs if the oven doesn't reach its tempt with in 50 mins
"ERR 3" means that the magnetron units have failed in the microwave.
Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the
microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave.
Magnets work inside a magnetron tube to create the heat and voltage
needed to cook items.
Bring the microwave back to the retailer or a repair shop for
service. You may also consider purchasing a whole new microwave if the
prices are cheap enough.
Hello, The F10 error code means that was a runaway over heating that occured in the oven. The things that could cause the over to overheat to the exterme of the F10 error code reqirements is during self clean normal cleaning temp. IF it wasn't cleaned just before the F10 error code,first the oven temtature sensor needs to be replaced then if F10 comes back after the sensor is replaced the computer control board needs to be replaced.
My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
