Panasonic KX-T7731 Corded Phone Logo
I hit "Intercom 107" to record my greeting but it asks for an extension. What am I doing wrong?
2 Related Answers
Anonymous
  • Posted on May 10, 2008
SOURCE: Recording greeting message
having same issue
Anonymous
  • 6 Answers
  • Posted on Nov 19, 2012
SOURCE: Automatic Intercom
Hi Raegan
in themiddle of the handset will be a button which is lit this button will say auto answer mute around it. Press this button will stop the problem.
Speak Soon
Phil
1helpful
How do I change the main greeting on MLS-12D program?
This is what I have:
Intercom 777
99#
password 1234#
9
* # (to by-pass selector code changes)
press 1 to record a new greeting, when done, press 1
* # to save changes
Need directions for recording the greeting on the main line of system
To enter voicemail administration, press Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. Once you have entered the password you will see 3 selections you can make .Use the three soft keys under the display and select AA (auto Attendant). Next, press greeting and greeting again. Next, it'll ask for the greeting number your probably working with greeting 1. Press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
5helpful
T7316 Change recording of Company Directory
To re-record the main greeting on most Nortel voicemails, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
1helpful
I am trying to change the out going message How do you change the greeting?
To re-record the main greeting, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
1helpful
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
1helpful
How do a change the answering machine message - what feature no. do I use?
To re-record greetings, enter Feature 983 from a M7310, M7324 or a T7316 set. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
I would like to change the voicemail/message that is on our phone. Only 1 guy had password/code to do it and walked out on us. Voicemail instructs caller to call him. Desperate need here. Any help would be...
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished. If he changed the password, then reset the administrator pasword by entering feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
2helpful
We have the Norstar Meridian (M7310) telephone system and would like to change after hours message. I cannot locate this information in our book. How do we change it?
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting either 2 or 4 (you might want to listen to the greeting first). press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
On Partner VS, I recorded greeting, but how do I turn on?
On your system press Feature 00(left intercom)(left intercom) #206 enter 01 then 1. Repeat procedure for all the lines in the switch that need to be going to AA
1helpful
Can you help me?
Well, you are heading down the wrong road. To change the Auto Attendant message:
Dial Intercom 777
When prompted for the mailbox and password:
Mailbox "0" followed by the # sign
"1234" followed by the # sign
option 3 will allow you to change the recording.
To change the display names on an extension:
AT EXT. 10 OR 11:
Press "feature 00"
Press the LEFT intercom button twice
Press the RIGHT intercom button and the display will say "Extension program" enter extension you want to program
Enter the valid intercom name(see table below)
file?id=dgs6spp6_5ctm7dcfn_bIf you make a mistake, press mic/hfai to start over
feature 00, when you are done.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
