Question about Hoisting
Where is blue giant blue pallet jacks situated in SA?
2 Suggested Answers
SOURCE:
  • 152 Answers
SOURCE: I'm pulling the lowering lever, why won't the forks on my pallet jack go down all the way?
First of all, the forks are not supposed to go all the way down to the floor, that would defeat the purpose because they would drag and you wouldn't be able to pick up a pallet. But if you think the forks should be able to go down further, just stand on the forks while pulling the lowering lever. You may need to grease the machine
Posted on May 27, 2013
Pallet does not lift
Hi is it electric or a manual pump up with the handle type if its one these check the oil level in the unit it may just need more hydroloc oil added or the valve on the actual jack of the unit its self are leakin and need replaceing dont use it like this as very dangerous
May 09, 2016 | Pramac GX565AUV000 NA GS Series 5500...
Pallet jack will not go down
Is it a manual pallet jack? At the base of the arm you will see a lever that the handle controls (usually it is at the end of the chain). Assist the lever by pushing it in further than the handle can able. That should allow the lift to lower. Sometimes the pallet needs to be level to lower. If it is a powered lift, check the limit switches. Good luck!
Feb 21, 2016 | Cars & Trucks
I have a 36ft winnebago Chieftain on a F53 chassis. I need to replace the fuel pump in the tank but the leveling jacks seem to go around the tank any idea how I remove them to get to the tank. If at
I dropped the tank on a 34' Fleetwood with the same situation. The jacks were welded on so there was no removal option. What I did was (1) Cut eight 4x4 s into 12" sections. I bolted 4 sections together to make a "pad". One 8" 4X4 makes two pads. (2) Then I pumped the fuel into drums. Free drums are easy to find. A cheap 12V fuel pump and tubing is available from any auto supply. (3) I raised the camper on all 4 jacks. Than I retracted one jack, set a pad in place under it and extended the jack fully. Clockwise I put pads under all the jacks one at a time to make a layer. Then I put in another layer of jacks, round and around, and continued until the camper was up 4 layers. (4) The camper could "roll" forward off the jacks at this point because the wheels were off the ground. I attached a chain to the camper frame and took tension backwards using a come-along chained to a tree. (5) Then I got some pallets from the grocery store trash and put those under the tank. (6) I loosened the hangers for the tank and let it down on the pallets slowly. The hoses have to be removed before the tank drops very far. I worked the pallets out one layer at a time to lower the tank to the ground. (7) I could reach the pump mounting plate so I just removed the screws and lifted out the pump and gasket. (8) installation was the reversal.
If I had to do it again, I would take it to Camping World or a truck garage. They have lifts to raise the camper and jacks to raise and lower the tank.
Nov 22, 2014 | Cars & Trucks
May 27, 2013 | Hoisting
What is the difference between a manual pallet jack and a powered pallet jack?
As the name suggests, for manual pallet jacks you walk behind the forks and pump the handle to raise them/lower them. On powered, or electric, pallet jacks, there is a throttle for moving and a lever for raising/lowering the forks. On some powered pallet jacks, there is a platform for the operator to stand on
Are there any other common names for pallet jacks?
Pallet jacks may also be called pallet trucks, pump trucks, or jiggers
Code c-14 for toyota electric pallet jack
toyato pallet jack electric , DISCUSSION FORUM - Forkliftaction.com
www.forkliftaction.com/forum/thread.asp?trid=15922
Dec 24, 2014 - 4 posts - ‎2 authors
California, United States, I have 7hbw23 toyota pallet jack with error codes c14 and e115 e112 trying to find code list or repair manual any ... toyota pallet jack . Discussion about troubleshooting ...
Dec 30, 2014
Error Messages for Walkie 102XM. Discussion about ...
May 6, 2009
More results from www.forkliftaction.com
Forum discussions - FORKLIFTACTION, Search this ...
www.forkliftaction.com/search/search_results.aspx?searchall=y...3
RESULTS 1 - 20 - 7HBW23 pallet jack no power, no fault codes. Lifting machines ...Toyota Electric pallet jack. Lifting machines ... error code C-28. Mechanical ...
toyota forklift manual 7hbw23 code c14 pdf - P(1) - srdt.sotite ...
srdt.sotite.com/pdf/1/toyota-forklift-manual-7hbw23-code-c14.html
Toyota electric pallet jack 7hbw23manual.pdf - WordPress.com ... I have 7hbw23toyota pallet jack with error codes c14 and e115 e112 trying to find code list or.
Code c-14 for toyota electric pallet jack - Fixya
www.fixya.com/cars/t12123378-code_c_14_toyota_electric_pallet_jack
Mar 22, 2012 - I have code c-14,try to fix it ... Hi Danny: One of the things that I do is to try to help resolve the problem, and that does not always mean answering ...
Mar 22, 2012 | Hoisting
Hoisting Logo
929 people viewed this question
Top Hoisting Experts
JAIJITH
Andrew Taylor
Andrew Taylor
Pierre Laplante
Are you a Hoisting Expert? Answer questions, earn points and help others
