Invacare Pronto M51 Power Wheelchair Logo
r
robert cook Posted on May 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove drive wheel - Invacare Pronto M51 Power Wheelchair
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Jun 10, 2016
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129704
Points
552
The drive wheel has a locking tab washer under the bolt which holds the wheel assembly on the end of the drive shaft. Step one is to bend the tab (or tabs) away from the side of the bolt. Put a socket on the bolt to remove it. Make note of the washer and lock tab orientation because there is another tab on the inside which locks into the motor shaft keyway. Spray lube into the shaft and keyway to free up the wheel and remove. A wheel puller is sometimes helpful here. When replacing the parts use Loctite on the bolt and tighten. The final step is to bend a lock tab up against the bolt head to keep it from backing out. The hard part of this whole process is removing the wheel assembly from the motor shaft. It may have seized on to the shaft. Place anti-seize or grease on the shaft after cleaning and before reassembly.
invacare com
How do I remove rear hub assembly on a 2004 front wheel drive Chrysler Pacifica
the rear hubs on a front wheel drive car are removed in the same manner as a rear wheel drive car with no front wheel drive
in effect the car is reversed on the chassis all procedures are the same
1helpful
3answers
I have 04 vue. Fwd 3.5. How do i change out right side cv axle? I can't free end that goes into carriage bearing?
remove lower ball joint and remove axle nut in the center of spindle. then move the spindle out of the way separating the axle from the spindle.
Clutch replacement
Clutch replacement will requre the removal of the transmission. If it is a rear wheel drive the trans can be removed fairly easily. Front wheel drive autos have the engine and transmission mounted in a "transerve" (across) fashion and require more time for removal. rear wheel drive requires the removal of the driveshaft (not difficult) and the front wheel drive requires the removal of the drive axles( can be difficlt). If your not mechanicly inclined and have a fair assortment of tools and equipment, this job is best left to a quailified person. You need Jack stands, floor jack, transmission adaptor, and if it's a front wheel drive, you will need an inpact gun to loosen the axle nuts on the drive axles.
2helpful
How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the wheel.
  3. Remove the wheel drive shaft nut.
  4. Remove the brake caliper and wire aside.
  5. Remove the brake rotor.
  6. Disconnect the electrical connector from the wheel speed sensor.
  7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
  8. Remove the 3 hub and bearing assembly bolts.
  9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
  10. Remove the hub and bearing assembly from the steering knuckle.
To install:
  1. Install the hub and bearing assembly to the steering knuckle.
  2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
  3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
  4. Connect the electrical connector to the wheel speed sensor.
  5. Install the axle nut to the wheel drive shaft and hand tighten.
  6. Install the brake rotor.
  7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
  8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
  9. Install the brake caliper.
  10. Install the tire and wheel.
How to removal the shaft from the rear end to
In order to remove the rear wheel, it is not necessary to remove the drive shaft. The first step is to get your rear wheel off the ground. The easiest way to do this is to put your bike on its center stand. However, not all bikes have center stands. If your bike does not have a center stand, you may want to buy a motorcycle lift (available from Pep-boys, or Harbor Freight). Once the rear wheel is off the ground, you can disconnect the brake linkage, and then remove the rear axle.
At this point there is nothing holding your rear wheel to the bike except for some meshing gears. Now you must lift and maneuver the rear wheel back and forth a little and eventually the final drive will work free. You will be able to slide the wheel toward the right side of the bike and then lower it to the ground.
In theory removing the rear wheel is that simple. In practice, the gears in the final drive can sometimes hold on quite tightly. This is particularly true if the rear wheel has not been removed for a long time or if your final drive is very worn. Usually being patient and persistent will pay off and you will be able to remove the rear wheel.
Sometimes it may prove easier to remove the entire wheel / final drive / drive shaft assembly first, and then separate them. In this case, the order of operations is different. Once you have the rear wheel off the ground, you can disconnect the rear brake linkage just as before. Next you can remove the four bolts that hold the drive shaft housing to the back of your crank case. Finally you can remove the rear axle and slide the wheel backwards the unmesh the drive shaft.
Regardless of which way you remove the rear wheel, it will be easier to put it back together by first attaching the drive shaft and final drive to the crank case, and then reinstall the wheel as described in the first method above.
Good Luck,
-Josh
Cant get the rotor off of a 99 , any suggestions
Remove the brake caliper, and caliper holder if it goes over the rotor. If it's 2 wheel drive, remove the center cap, take out the cotter pin. Remove the nut holding on the rotor. If it's 4 wheel drive, once you remove the associated brake parts, spray some WD-40 around the studs and the center of the rotor, try striking the rotor with a rubber hammer. Often the rotor will rust to the hub, on the 4 wheel drives. The 2 wheel drives, have the rotor with the hub for the bearings together, the 4 wheel drive has a "top hat" type rotor.
2helpful
Is a 2002 isuzu rodeo front wheel drive ? And do you have to remove the axle to replace a transmission
There are no front wheel drive rodeos but there are 4 wheel drive and all wheel drive. If it is not 4 or all wheel drive then there is no front shafts. You will need to remove the rear drive shaft though to remove the transmission. Hope this helps. Good luck.
I have a Disco II and the wheel hub bearing went and i'm tryign to change it but i cant seem to get the hub off, can any one help with a step to step guide or something, thanks.
RAVE says the following:
1) Release ABS Sensor harness grommet from inner wing valance and disconnect multi plug.
2) Raise front of vehicle.
3) Remove road wheel.
4) Pull ABS Sensor harness through aperture into wheel arch.
5) Release harness from brackets on inner wing valance, suspension turret and front hub.
6) Release stake from drive shaft nut
7) Remove drive shaft nut with assistance & discard.
8) Remove front brake disk (Remove calliper, pad holder, screw and tap to remove)
9) Remove 4 bolts securing wheel hub to steering knuckle.
10) Release wheel hub from steering knuckle then remove wheel hub and drive shaft assembly from axle. DO NOT REMOVE ABS SENSOR FROM HUB. HUB AND SENSOR ARE SUPPLIED AS AN ASSEMBLY.
11) Position the wheel hub and drive shaft on a press, place supports beneath the wheel studs and press the drive shaft from the wheel hub.
12) Remove drive shaft oil seal from axle casing.
Refit is mostly the reverse, you need to take care to lubricate things in the right places and put loctite on the drive shaft and locate the loom and torque everything right.
1helpful
Removal of dragstar 1100 rear wheel
if it is shaft drive like my 650 then remove all bolts holding final drive to frame loosen rear wheel spindle and remove wheel with the whole drive, shaft and all will come with it, then take out the spindle and remove the drive..
2003 trailblazer lt 4wheel drive
  1. Remove the tire and wheel center cap.
  2. Remove the drive axle nut.
  3. Raise and support the vehicle. Remove the tire and wheel. .
  4. Remove the brake rotor.
  5. Disengage the wheel drive shaft from the wheel hub and bearing. Place a brass drift against the outer end of the wheel drive shaft in order to protect the wheel drive shaft threads. Sharply strike the brass drift with the hammer. Do not attempt to remove the wheel drive shaft from the wheel hub and bearing at this time.
  6. Remove the wheel hub and bearing from the steering knuckle by removing the three bolts coming in from the back side of the knuckle.
Of course you may have to use a hammer to loosen the bearing from the knuckle.
Good Luck
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
