Taken off when stopped using tomtom but want to start again
SOURCE: i can't start my tomtom
Reset your device:
http://www.tomtom.com/support/index.php?FID=6965&Lid=1
Download TomTom Home from here:
http://www.tomtom.com/support/support.php?ID=3&Language=1
Also see:
http://www.tomtom.com/support/index.php?Language=1&query=device+wont+start&FID=7375
SOURCE: frozen tomtom go 910
Hi, Not a nice problem that. Try connecting your tomtom to PC ( not through home ) so the tomtom will look like a USB drive in "My Computer". if TomTom Home tries to load up , cancel it. Look in "My Compuer" If you do see the TomTom as a drive , open it up and copy the folders and files to your PC. If that works, now you have a backup and you can have a mess around knowing that if you mess things up , at least you can put things back as they were and you won't have made anything worse than it was before. Once thats done , try a harder reset in normal way but also hold the ON button in whilst doing the reset . Many people press too hard on the reset button and also hold it too long so just give one single press , only hard enough to feel it click in , then out. Thats all it needs for a reset and it avoide damaging the switch ( yes , I have seen many reset switched stuck in or broken ). I think theres 2 possible causes for your problem . 1/ You now have a corrupted file on your TomTom preventing the boot-up continuing. 2/ Your Tomtom is still trying to perform the last function ( backing up through TomTom-home ) and has somehow got stuck in that loop. For the moment , try the above and see how you get on and if you donn't solve it please post on this forum again .
Good luck .
SOURCE: My computer can not find driver to install TomTom Home
I am the original poster, rdsrds2, and after 4 go arounds with TomTom tech support I finally got someone who knew exactly what to do. My problem is solved. Some of the other solutions posted here may be equally valid. To all who are having installation problems, here is the download you want:
http://download.tomtom.com/sweet/application/releases/v2_3_1_92_win.exe
SOURCE: how to install tomtom home
Good day, Kindly please explain to me how to install my TomTom ONE EUROPE 22 Navigate.
I want to install the TOMTOM HOME Softwre and I was told to asked through the web-site and if this you be help foe me.
Thank you
Dee
It's likely that your map (data) got corrupted. You can recover by restoring your back-up copy of the map (that you'd previously done via TomTom HOME on your computer).
If you don't have a back-up copy, try using your computer's disk check utility to fix the file system and recover data (from the storage media on your GPS device). Just connect the GPS to your computer, no need to use TomTom HOME, just use the Properties tab and use the Tools to run a disk check (assuming you're using Windows).
If that doesn't work, you may want to purchase & download and install the latest copy of the map from the TomTom website (via HOME).
