Lands Phones Logo
Cant acces lines but i already programed - NorStar Lands Phones
I tried to turn key cylinder radio comes on car won't start security light on can i bypass ? i already turned off alarm with door key. husband already lost job because of this we cant afford to fix
The security, antitheft or lock picture/icon is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterprets this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. This link explains it pretty well.
http://www.diy-gm-security.com/
Cant acces to d net but i activateted my GPRS already. my network is globe
you can contact the service provider.....................
Aug 27, 2011 • Nokia 6600
I need adobe photosjop but i cant acces and wich one is best?
I prefer using a FREE program called GIMP. You should check it out.
It's really easy to get many of same effects.
GIMP WEBSITE
--RescueTechLA
How du i get on line on my psp, i cant figure it out
open ur psp go right open web press on it scan for wirelees acces points connect to it and enjoy
2003 chevy trailblazer. alarm problem 771xv
CHECK THAT YOUR BYPASS POWER IS ONNECTED TO THE ACC.CABLE FOR IT WILL NOT DRAIN YOUR BATTERY
Connecting to the acces point (router) but not to the internet
I had a similar problem and solved it this way: Go to Start > All Programs > (the name of your USB adapter). In that folder there should be a "manager" or some type of program. Run it. One of the settings should read "AP mode" or "Station mode". When I switched from AP to Station, suddenly a list of available networks popped up. And my problem was solved. Hopefully that will work for you too. GregM23
I cant acces all of my programs and add or delete any
change ur user option from limited user to adminstartor if this is not helping tell me!!
rate me fix you!!
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
