Question about Hobart Dishwashers
Hobart hl662 error code 18, runs for a bit, then stops randomly. Any help would be appreciated.
    Habit-Forming:
    New Friend:
  • 43 Answers
Check bus voltage.
Any short to ground?
Contactor malfunction?
Check motor resistance?
Posted on Oct 18, 2016
    Habit-Forming:
  • 36 Answers
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
We have a Hobart CCH50D with an error code of E09 element has been replaced but will not fill & run. Has the error code to be removed ? if so how please
Error 09 is boiler not filled.If the element had blown, its like this was due to the fill solenoid failing.
Sep 20, 2017 | Hobart Dishwashers
2005 Wrangler Unlimited. Why does it die suddenly?
Please Help! 2005 Jeep Wrangler Engine Suddenly Stops While ...
www.wranglerforum.com/.../please-help-2005-jeep-wrangler-engine-sud...
Oct 11, 2009 - 30 posts - ‎17 authors ... suddenly stopped on my 2005 Jeep Wrangler TJ while I was driving. ... 20 seconds later, engine suddenly died exactly as it did last week. electrical problem? shuts off while driving
Sep 29, 2012
Sudden loss of power
Mar 9, 2012
Speedo not working and dies randomly
Dec 4, 2011
won't start, won't crank
Nov 20, 2011
More results from www.wranglerforum.com
Aug 11, 2015 | Jeep Wrangler Cars & Trucks
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
Hobart battery charger
model # 750H3-18 hobart charger gets a abonormal shut down light after overnight charge on different machines.
Feb 11, 2010 | Hobart 24 in. LXIC-5 Built-in Dishwasher
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
LX-18 error code E4 what is the problem? Replaced motor runs great.
the water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Mar 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
169 people viewed this question
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
