Tablets & eReaders Logo
L
Laurence A Nicholls Posted on May 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you connect ipad to computer - Tablets & eReaders
guruaid_cs
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 906 Answers
  • Posted on May 16, 2016
guruaid_cs
Master
Level 3:
Renaissance:
Answers
906
Questions
0
Helped
153310
Points
2073
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
Connecting to ipad
Connect iPad via Wi-Fi
  1. Connect your iPad or iPad mini to your computer.
  2. In iTunes, when your tablet appears in the Devices list, click it. ...
  3. In the Summary tab, select the Sync with this iPad over Wi-Fi check box.
  4. Click Apply. ...
  5. Click Done.
  6. Disconnect your iPad or iPad mini.
Wanted to transfer from an iPad mini two to an iPad 4
It's easy. There takes transferring music as an instance. Just follow the below steps.
Step 1 Start Leawo iTransfer
Connect old iPad to computer via USB cable. Start Leawo iTransfer on your computer. The software will automatically recognize your device and shows iPad library in the left sidebar.
Step 2 Select music to transfer
Click the name of iPhone and go to "LIBRARY > Music" in the left sidebar and select multiple songs in the right interface by holding "Ctrl". Right click them to choose "Transfer to > My Computer".
Step 3 Transfer music from iPad to computer
In the pop-up window, chose "Save to folder" and click on "Change" to select an output directory on your computer. After that, choose "Transfer Now" to transfer music from iPad to your computer.
Step 4 Transfer music from old iPad to new iPad
Disconnect iPad but connect new iPad to your computer. Go to "iPad > LIBRARY > Music" in the left sidebar. Choose "File > Add > Add File or Add Folder" in the top middle to upload music you just transferred from old iPad to your new iPad.
For more details, check: How to Transfer Music from iPad to iPad
2answers
How do you connect ipad to computer?
You use the USB cable appropriate for your model of Ipad
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
Ipad password reset
In fact, there are different ways to reset iPad password. You can follow below method to have a try.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
Connect iPad to computer
You first need to install APPLE ITUNES..
http://www.apple.com/itunes/download/
once its done connect the usb cable to the IPAD FIRST,
then connect the USB cable to the computer.
this will detect the ipad , install the drivers and launch iTunes so you can transfer your music and such.
4helpful
5answers
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
