Lexmark X5470 All-In-One InkJet Printer Logo
c
cathie s Posted on May 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power cord for lexmark x7170 all in one printer. what is the code or part #
Jeff Bird
Level 3:
  • Lexmark Master 1,348 Answers
  • Posted on May 15, 2016
Jeff Bird
Lexmark Master
Level 3:
Answers
1348
Questions
0
Helped
363413
Points
4615
Hi u can buy them on E/BAY..type in e/bay search---- 2- prong AC power cord cable lead for Lexmark printer scanner ac adaptor charger cost AU $3.20 good luck
X7170 not powering up
Try this approach:
1. Remove the power adapter from the printer. The power adapter is the black box where the power cord is plugged in at the back of the printer.2. Disconnect the power cord from the power source.3. Reconnect the power cord directly to the power outlet in the wall. Bypass any surge devices or power outlets.4. Re-plug the power adapter into the printer.5. If the printer won't automatically power on, press the power button on the printer operator panel.
I hope this helps.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
My lexmak x7170 does not display on screen and does not copy or fax
Is your printer even powering on? Try to remove the power adapter from the printer(small black box behind the printer where the power cord is attached).
Before reinserting the power adapter, check if it's warm or cold. It could be a defective power adapter issue. Wait at least 10 seconds before replugging the power adapter. That should give enough time for your printer to reset itself.
Check if your printer is functioning now.
I misplaced my powercord for my lesmark X7170 where can I purchase one from
Hi, try to check first if your power cord should be a 3-prong cord or a 2-prong cord by checking the power supply behind the printer where it should be plugged in. Then, check at your nearest electrical/electronics shops around your area if it's available. Otherwise, try to call Lexmark and check if they can assist you with that. I hope I could help you more with that. Good luck!
AC adaptor
Hi there
You can buy one from any good pc shop, I put a link so you know what you are looking for, the cord is the as some radios have.
http://cgi.ebay.co.uk/NEW-AC-POWER-CORD-Lexmark-X5470-X7170-X8350-X9350-cable_W0QQitemZ260544268281QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca9a607f9
Part number needed
Maybe you didn't lose it .......The x7170 doesn't have a black box, it has a power cord only.
Loads on eBay: search for <x7170 power cord>
e.g.
http://cgi.ebay.co.uk/AC-Power-cord-cable-for-Lexmark-X5470-X7170-X8350-X9350_W0QQitemZ330393246960QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cecf8dcf0
Hope this helps
1helpful
2answers
I moved and lost my power cord for my lexmark x7170. Just need another one! Any ideas
Is is just a power cord - they have tons of them at Goodwill, Savers.....I even pick up USB printer cables for $2 (instead pay $25 at Best Buy)
If the cord contains a transformer (black box) - then you will probably have to order one online (for the best deal).
NEED POWER CABLE FOR LEXMARK X7170
Just go online at www.lexmark.com Go to the All in One Printers and type in the X7170 and find the part that way.
Or you can just call Lexmark Technical Support and get them to connect you to the parts ordering center.
Don
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
