Fire wire is old and never competed with USB. They may be able to transfer data, but you probably fried your camera. Possibly due to older USB format.Fire wire is old and never competed with USB. They may be able to transfer data, but you probably fried your camera. Possibly due to older USB format.
You can't post conmments that contain an email address.
see this topic and contact the supplier .God bless you
FireWire connection to
computer keeps getting dropped. Check with manufacturer to make sure you have
the latest driver and firmware updates for your camera and computer. Always
turn the camera's power on before making a FireWire connection. Disconnect the
FireWire cable before turning the camera off. Use the camera's AC adapter when
making FireWire connections. Try a different FireWire cable and try connecting
the camera to a different computer. FireWire cables and ports sometimes fail.
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging. Low-powered USB port iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information. Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer. FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod. Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge. hope this helps
First, you need a Firewire connection (also called IEEE 1394). Most of
PC computers don't have it, including mine. I bought a cheap Firewire
card and installed it into an empty PCI slot, costed about $15. I hope you don't have the USB cable and the firewire cable plugged into
your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and
the firewire port of the computer and the camcorder is in Play mode (and
plugged into the wall AC power with the power adapter), are you saying
that when you launch MovieMaker and "Capture", the video camera is not
recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do
you know it is working?). If you are using Vista Home Basic, chances are
good that the IEEE1394a firewire port drivers were never loaded... so,
that will be your first step. Get that port working and you'll be ready
to go.
2) The DV port on the camcorder is not working properly. This could be
for several reasons, but lets hope the DV port was not fried if you ever
had the USB and firewire connections to your computer at the same
time... Reset the camcorder to factory defaults by disconnecting all
cables, removing the rechargeable battery and removing the little
date/time button battery inside the camcorder. Wait for about 20
minutes. Put the button battery back in, then put the rechargeable
battery back on. Set the date and time. Connect the firewire cable to
the DV port, connect the AC power adapter to the wall, connect the other
side of the firewire cable to the firewire port on the computer, launch
MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an AppleMacintosh and iMovieHD? You will need a
4-pin to 6-pin firewire cable and the AC power adapter. If it works with
the Mac, we know it is not the camcorder's DV port. If it does not
work, chances are good the camcorder's firewire port is bad. Hope this was helpful?
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Kodak has 3 types of charger that can be connected to a wall socket USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera. 5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V 3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
I use WINXP Pro and there is no problem. I can only offer the steps that I use for you to see if it makes any difference. Sometimes the sequence can be the answer.Try this twice, once with the battery in the adapter and once without the battery. 1. Power down PC. 2. Disconect camera from PC. 2. Power up PC. 2. Make sure the camera is off. 3. Remove battery from Camera. 4. Plug adapter into mains (with or without battery) 5. Plug camera into adapter. 6. Plug camera into PC with firewire. 7. Switch Camera on
