SOURCE: working on farmall super a tractor distributer had
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of manufactured products made for consumer use
