Look around the machine for a plastic envelope with what is called the Tech Sheet in it. It should give you an idea of what the beeps and flashing l.e.d. lights might mean...Look around the machine for a plastic envelope with what is called the Tech Sheet in it. It should give you an idea of what the beeps and flashing l.e.d. lights might mean...
You can't post conmments that contain an email address.
Try a power cycle before replacing any parts. You can also turn your dial counter clockwise and retest the wash. Otherwise, I would suggest setting up an appointment with home depot to get a full list of parts that need to be replaced in your washer.
This could be anything from a faulty water valve , machine not draining , faulty electronic board , faulty timer unit ...For the machine to continue it must complete its last cycle . Any fault codes showing ?, was it filling , was it draining properly ??, please contact your registered whiteware technician for proper fault diagnosys , cheers .
Hello there: If your cycle does not complete or The cycle doesn't advanceWhen the cycle should advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. than check the cold water supply line and the filter
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
