Seiko Global R-Wave Radio Controlled Travel Alarm Clock - Calendar - Logo
C
Carol McRae Posted on May 12, 2016
How can I get the correct day of the week? I can get the date-month & day, but not the correct day such as Sat when the clock says Monday.
pete musca
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on May 12, 2016
pete musca
Contributor
Level 1:
New Friend:
Answers
38
Questions
Helped
13719
Points
91
Check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
I have an 'HPI Can you Imagine' suspended animation clock. Can it be reset for current year and time.
All days and months re-occur and repeat.
Months and Years having Monday the 26th
Time and Date https://www.timeanddate.com > weekday-monday-26
Year Date Month Since last Comment 2010 Monday, April 26, 2010 April 2 times in year 2010 2010 Monday, July 26, 2010 July + 3 months 2011 Monday, September 26, 2011 September + 14 months 2 times in year 2011 View 67 more rows
After the factory-set time for the time change (which was not correct), the day-of-the-week display jumped a day so that it will show Tuesday when in fact it is Monday. How do I correct this error?
Harlyn,
Have you checked the year also. That is the only item you have not mentioned. If the year is wrong then the day may be wrong. So, you must set the time, date, month and the year, then only would you get the correct day.
1helpful
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
6helpful
How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
4helpful
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
4helpful
Can't get the day of the week to go with the month and date
You have to set the calendar for the correct year. To see the year, you have to press the time & month/date buttons altogether. You will see the display change from month/day to year. Use the set+/Set- buttons to change the year to the correct calendar year. This will fix the day to work with the month and date.If you keep having this problem, you will need to change the internal battery. I hope this information help you with your problem.
2helpful
Day of Week
Yourl calendar year may be wrong. If the calendar needs to be reset hold down the month/date & time buttons. Press the up or down button based on you have to baclward or forward.
Clock day different from date
This is probably a stupid question but you do have the year right in the date?
Is the date format correct?
UK day/month/year
USA month/day/year
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top Seiko Audio Players & Recorders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
SmartAviator
SmartAviator
Are you a Seiko Audio Player and Recorder Expert? Answer questions, earn points and help others
