Cars & Trucks Logo
M
Mary Christine McWilliams Posted on May 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Should there be keys for the N15115 and which batteries are needed?
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on May 13, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058712
Points
266281
Batteries full turn the key on nothing at the key switch does the key fob need to be working with the battery inside of it
It's possible that the key fob battery needs to be working in order for the key switch to function properly, especially if your vehicle has an electronic security system. Some key fobs are designed to work in conjunction with the vehicle's immobilizer system, which prevents the engine from starting without the correct key fob being present. If the key fob battery is dead, it may prevent the immobilizer system from recognizing the key and allow the engine to start.
However, there may be other reasons why the key switch is not working, such as a faulty ignition switch, a blown fuse, or a dead starter motor. If you have already confirmed that the battery is fully charged, you may need to have your vehicle inspected by a qualified mechanic to diagnose and repair the problem.
How do I open n15115 doors locked have forgotten pin
  1. Check for hidden key: Some locks have a hidden key that can be used to open the door in case you forget the pin. Check for a keyhole or other opening that might contain a hidden key.
  2. Use a lock pick: If you have experience with lock picking, you may be able to open the lock using a lock pick set. However, this requires a certain level of skill and may not be the best option for everyone.
  3. Call a locksmith: A locksmith can open the lock for you using specialized tools and techniques. This is typically the most reliable option, but it may also be the most expensive.
  4. Contact the manufacturer: If you are unable to open the lock and cannot remember the pin, you may need to contact the manufacturer for assistance. They may be able to provide you with a new pin or other options for opening the lock.
It is important to note that attempting to open a lock without the proper knowledge or tools can damage the lock or cause other issues. If you are unable to open the lock, it is generally best to seek the help of a professio
I have a 2006 Jeep grand Cherokee my key fob alarm stopped working put a new battery in it what else can I do
The key fob will need to be reprogrammed to the vehicle since when the battery was replaced in the key fob, the key was reset. This is why nothing is working with the key fob. After replacing the battery in the key fob remote, you will need to reprogram the remote to the vehicle
1helpful
2answers
2004 ford exp 4.0 with new starter and battery. It sat all winter with no battery. Now the anti theft wont let the key chip turn over the starter. All instrament lights go on.
If this doesn't work you will need the help of a clever person with suitable equipment...
Try disconnecting the battery and leaving overnight. Next morning fit the ignition key into the steering lock and switch on - then connect the battery.
It sometimes works...
3helpful
4answers
I have a 2001BMW X5 and my key functions don't work dose it need a battery and do I need togo to BMW and how much will it cost?
Yes, most likely you need a battery in the key fob. No, you don't need to go to the dealer. Most any parts place will have the battery, and should even help you install it.
How to re-start my car after anit theft light has come on?
you need a full charged battery or battery replaced [if battery bad and not holding charge] your remote key fob will not work if battery is dead or to weak to start car but key should be able to manually open drivers door --if its not an original key new cut or worn down [may have to jiggle in door ] your anti theft/security lock will come on when you use key in door than you have a few seconds after you open door to put key in ignition and turn to on position before alarm goes off but you need to get battery issue corrected first if key still doesnt work may need to have assistance [slimjim]lock to get in
How do I replace the key battery on my 2005 Chrysler Town and Country?
to replace your battery you only need a 1/2 inch socket to remove the battery holder bolt which is located on the left side of the battery then loose the battery terminal and you ready to replace the battery, if you do a replace in less than 4 hours you do not need to reprogram the key neither the remote.
11helpful
How do I change battery in my lr3 key fob
You do not change the battery as it is re-chargeable. It is charged in the key fob unit while it is in the car's ignition and while you are driving the vehicle.
If you have a spare key that has low battery power then it needs to be used in the vehicle to charge the battery.
If you have been using the key fob and it has suddenly failed this is probably due to a faulty circuit board. You will need to replace the key fob with a new one from the dealer. It needs to be programmed for your car by the dealer.
Always have a spare key for this vehicle and keep the battery charged by using it occasionally.
2answers
1994 0lds 88.turn on key and get nothuing battery good
battery might be good but the battery cables might be corroded needs cleaning & make sure they are tight but don't over tighten they will brake battery wiggle battery cables on battery & see if lights come on i can almost bet its in the battery cables on the battery
5helpful
4answers
Replace battery in key
If you have the diamond shape key, the battery is not replacable. If you have the square shaped key, the battery is replacable, but that is obvious because of the screws on the back of the remote.if you have the diamond shape key, it is recharged when its inserted into the ignition. If the key hasn't failed, taking a long trip 60 min. or longer should recharge the battery. If there is no change in the operation of the key after your long trip, most likely the key has failed and needs replacement.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
