SOURCE: i have a 57
If the dot is there whatever the image source / input are you using then the defect is in the DLP panel - the mirrors from the panel corresponding that dot aren't commanded anymore. It can't be fixed, the panel must be replaced. It will be expensive.
SOURCE: We are having white dots
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Testimonial: "Thank you so much. I will follow up. We love this TV and can't imagine just having to toss it out. I'll let you know how we make out. Gratefully, es"
SOURCE: just paid to replace the
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
SOURCE: How do I repair white dots/dead pixels on my 3
You have a bad light engine. It is available at encompassparts.com for retail price of $749.10. Call 1-800-638-3328. Consumer not in business could be higher price.
