Washer will not pump out water or spin. I need to be able to find codes and what they refer to. The full model number is MTW 6600TQ0
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
SOURCE: I have a maytag top
based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
SOURCE: Model; MTW 5870two Washer will let
Hi
The issue is with the lid switch-lock assembly that is bad and should be replaced. Please check this diagram....part#8 is the lid switch that should be replaced. Hope this helps...please post back for further assistance.
Daniel
