Question about RIM BlackBerry Pearl 8100
How to fix a blackberry with a broken screen that shows nothing
It is broken under the screen and a whole load of weird colours showup when i turn it on
Whenever I turn my Android Huawei on the home screen never shows up, instead theres a black screen with a weird message
factory reset ur phone once... an see if it is fixed or reflash the os that can be done free of charge at the service center
Nov 25, 2012 | Android Huawei
Blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Jun 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
I dropped my blackberry bold 9700 and the screen is white what does this mean
I'm sorry, but the LCD is broken. The good news is that Blackberry Bold LCDs are fixable. You can do a mail order repair or find someone local to fix it. Inovagent can repair your Blackberry locally in the Washington DC/Baltimore area.
Feb 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
Blank Screen
Sounds like you have a broken LCD screen. Go to your carrier, they might replace the phone for you altogether for free or at a discounted rate. If they refuse,the only way to get it up and running again is to open your blackberry2_bing.gif to physically replace the part. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how.
Feb 05, 2010 | Verizon Communications BlackBerry Pearl...
My blackberry bold shows yellow , green and blue colour, screen is unclear, please help
Sounds like you need a replacement LCD screen. If you would like to have us fix this for you email me at blackberryrepairshop@gmail.com
Oct 27, 2009 | RIM BlackBerry Bold Smartphone
Can i fix a all white screen??
If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how, the part is available on Ebay.
Sep 23, 2009 | RIM BlackBerry Pearl 8100
Blackberry Storm Screen
 There is a Blackberry Repair Guide that shows how to open a Blackberry 8900 Javelin and the storm is very similar. Check for any loose connections inside, otherwise you may need a new screen. Once it is open it's as easy as taking the broken screen off the front assembly and installing a new one, the parts are available on ebay. There are also third party blackberry repair services that will do this for you if you aren't covered under any other warranties.
Apr 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Screen Problems
The Backlight is a separate module actually called "FL Inverter" Its same logic like mobile Fluorescent tube. Most of the service centers keeps in stock as the issue is common regardless of brand. So whole module can be changed. Part is not really costly but workmanship might added on it. If you are able to replace I believe you can purchase the part as well.
Good Luck
Feb 05, 2008 | Samsung V20 XVC 2400 Notebook
RIM BlackBerry  Pearl  8100 Logo
144 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Ekse
Vincent G
Vincent G
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
