When I engage the blades, the belt moves around the Pulley Idlers, but the Pulley Idlers and blades do not turn. Is it the belt, Pulley Idlers, or something else to check to be replaced?
Depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
Thank you so much! I appreciate your time and precise answers regarding possible causes and what to try before I take it to the dealer nearby.
