reguardless of how much time elapses between uses the blower unit should alll ways be tested for (Back flow) after every use , this is when water gets back into blower unit and causes rust on drive shaft (sticking shaft) sometimes thiis can be compounded by the mixing valve (a device that mixes air and water ) going bad or sticking open with debris
SOURCE: Why are bubbles forming in my intex pure spa jet massage?
the air bubbler is switched on
there is a leak in the suction side of the pump that is sucking in air
