The computer went into sleep mode and I didn't get it charged. Then it might shut down automatically. Now I can't open it at all even I get it charged. The red little dot also doesn't light up when I connected the charger.
SOURCE: I tried to switch on my laptop and it started
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
SOURCE: My leney vo T61 lap
Please refer to the following article for a detailed diagnosis of your problem:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
SOURCE: lost power completely. It will
Hi scottj313,
Based on the information you've provided there are 2 possible causes for your system not to run with the charger:
1. Your AC Adapter is defective:
-> If the light for the charger is no longer illuminating chances are AC Adapter is defective.
2. The DC In is defective:
-> The port as to where you are plugging in your charger might be also defective. And if it is, your system will also not charge. This port is built in to your motherboard.
Now the fact that the system lost it's power completely is because there's no power coming in. Also, the incident prior to this that your system intermittently shuts down is probably caused by a defective AC Adapter. Seems like when it was moved the power stops flowing.
For hardware issues with your machine I recommend you to contact Lenovo's Tech Support. You may contact them at this number1-877-4Lenovo (1-877-453-6686).
Hopeit helps.
Thanks for using Fixya
SOURCE: My G550 lenovo just started shutting Windows down
go control panel
then power options
then find on the tabs power scheme
then try putting the turned off hard disk (never)
SOURCE: Targus COMPACT laptop charger isn't working
Chornic solar charger is designed to the highest technical specifications and standards ,It will supply years of maintenance free use. Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
