Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
