Used clock parts for sale We search the internet antique stores and yard sales for hidden treasures In addition to offering used clock parts we also provide information on how to...
If your wall clock is running but the pendulum is not swinging, it may be due to a few potential issues with the pendulum mechanism. Here are some steps you can take to repair the pendulum mechanism:
Check the suspension spring: The suspension spring is a thin strip of metal that hangs down from the top of the clock and holds the pendulum in place. Check to see if the suspension spring is properly attached to the clock and if it is straight. If it is bent or damaged, it may need to be replaced.
Check the pendulum leader: The pendulum leader is the part of the clock that connects the pendulum to the clock's movement. Make sure that the pendulum leader is properly attached to the clock and that it is not bent or damaged.
Check the escapement: The escapement is the part of the clock that controls the swing of the pendulum. Make sure that the escapement is properly lubricated and that it is not damaged or jammed. If it is damaged or worn, it may need to be replaced.
Check the beat setting: The beat setting is the adjustment that ensures that the pendulum swings evenly. Make sure that the beat setting is properly adjusted by moving the pendulum to the left or right until it swings evenly.
Check the weights: If your clock has weights, make sure that they are properly attached and that they are not obstructed or damaged.
If you've tried these steps and the pendulum still isn't swinging, it may be best to contact a professional clock repair technician for further assistance. They will have the expertise and tools needed to properly diagnose and repair any issues with your clock's pendulum mechanism.
It sounds like the drive spring might be worn. A Good clock and watch specialist will be able to overhaul and service the clock for you. It might cost you a bit more money but if it is a family clock it could be worth it.
If there is an identifiable maker of your clock, I would recommend you attempt to locate instructions pertinent to it. Perhaps there is additional help in a forum.
Hi Petah 920...I have also aquired the same clock, with the pendulum and other parts missing. I intend to fabricate the missing parts ( I am a clockmaker) and engineer. My problem is not knowing the exact parts, I have contacted Thwaites
mcdevito75 here, I would figure the pendulum serves 2 purposes, 1 it acts like a seconds hand on a watch and 2 more important it acts a s a counter weight keeping the clock in Balance. It sounds like the Pendulum mechanism needs cleaning and or adjustment, look for a small watch repair shop in your area, they can advise you on a clock repair shop in your area, or you can always check with the repair service directory right here at fixya, bottom of page, click on repair service directory the watches / clocks.
I had the same problem; I inherited a clock by that description with my office. I'm not sure if it would help you, but I was able to at least figure out the mechanics of the clock from this site: http://www.clockworks.com/cintro1.html
if you take it to a clock repair shop they should be able to repair the broken part and replace the magnet as you cant get the parts for this they have to be made i spoke to my locall repair shop and they said they could replace the magnet with an identical one and could repair the damaged part this is the only way u can do this as they dont sell the spares anyware i have used all my contacts and can find no one who can get these parts sorry i couldnt help you any more hope this is some help to you but you can get this repaired for a fee..............................
