You can create two-element lists and store the results in them.
Create a list L1 with dimension 2
Calculate the Polar coordinates of the point (1,1);: just an example
The 1st element of List 1 is the radius, and the second element is the angle (in radians). Convert it to degrees if you wish. I won't do it.
Now you must extract each element and store it in the r, and theta variables, [ALPHA][x^2] (r) and [ ALPHA] [^] (Theta)
Extract radius and store in r. Extract angle and store in Theta.
To store the rectangular coordinates (x,y) do the same as above. I will leave this pleasure to you.
Note: I inserted screen captures from my calculator but I am not sure if the Parser will accept them. If it does not I will create an image file and insert it as media.
never mind, found the answer. On the fx-300 MS version, when you do say Pol(4,4), the answer on the display is 5.65..., if you are looking for the second part of that answer, the theta, it's saved in the variable F, so press RCL, and then tan, and there you go, your theta value.
