Sewing Machines Logo
Carol Clark-Elliott Posted on May 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
R.A. Ellis
Level 3:
  • PfaFF Master 12,731 Answers
  • Posted on May 08, 2016
R.A. Ellis
PfaFF Master
Level 3:
Answers
12731
Questions
Helped
2610624
Points
59176
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
4 Related Answers
Anonymous
  • 41 Answers
  • Posted on Jul 31, 2008
SOURCE: fREE MOTION QUILTING
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
Anonymous
  • 1116 Answers
  • Posted on Feb 20, 2010
SOURCE: I am trying free motion quilting on my europro
It sounds like you are doing as you should.
If the darning foot is not "springy" enough and is holding down too firmly, you might look for a "hopping" foot.
I use the Supreme Slider and gloves to help me better move the quilt.
RichSew
Douglas Plant
  • 222 Answers
  • Posted on Jun 03, 2010
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Sep 01, 2010
SOURCE: I have this White model
to allow the free moving and to do it by hand ..it has a button that will low the feeding dog and practically you will move the fabric by hand..or ..just remove the presser foot from the screw..or if it is possible ..free the screw and lift the foot up to the max..for a larger feeding dimension ..
2answers
Is an Elna 2006 sewing machine capable of free motion quilting. The feed dog doesn't lower but I read you can use the darning plate to cover the feed dog- What should I set my stitch length at?
Can I Free Motion Quilt on a Regular Sewing Machine? By National Quilters Circle
Yes
https://www.nationalquilterscircle.com/article/can-i-free-motion-quilt-on-a-regular-sewing-machine/
How to Stitch the Perfect Stitch Length for Quilting
JULY 28, 2020
Today’s Topic: How to Stitch the Perfect Stitch Length for Quilting
https://lorikennedyquilts.com/how-to-stitch-the-perfect-stitch-length-for-quilting/
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
How to Free Motion Quilt on Regular Sewing Machine
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
2answers
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Pfaff free motion sewing
Ok.. first understand that free motion is just that.... there will not be a perfect stitch length... You are the regulator of that as you move the hoop. You'll need to practice. There are some good videos on youtube on this.
2answers
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
2answers
How do I set my pfaff mahine up for free motion quilting
try dropping the feed dogs, & reduce the top thread tension one number at a time till the stitches are normal
1helpful
FREE MOTION QUILTING
Hi Susan,
Happy sewing,
Kim & Linnette
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
